Francis Turbine on Brine Application
I am seeking a manufacturer of a francis turbine for use on the brine stream of a desalination plant. Materials of construction need to be super duplex stainless steel or cupro nickel.
Flow rate 1.9m3/s head 60m.
RE: Francis Turbine on Brine Application
www.gouldspumps.com -(Engineered pump division)
I googled Francis turbine and got a good response - might be worth checking further.
Had beeen doing a google search for months. Most leads faultered on the materials required for brine .
