Brick element 8-node using Workbench
Hi All:
I started to use ANSYS WorkBench (11.0). The simplified model was automatically generated with brick element (20 nodes).
The question is: "How can I reset or modify commands in order to obtain brick elements with 8 nodes only (not 20)?".
Thank you in advance.
Elkhorn.
Elkhorn.
RE: Brick element 8-node using Workbench
in the mesh controls, under "Advanced", just tell Workbench that you want "Midside Nodes -> Dropped".
