Reason for commissioning sets being in the return leg
This one has stumped me for a while and I can't seem to find an answer.
Why are commissioning sets always specified as being in the return leg of a LTHW system?
Is there a logical reason or just tradition?
Much obliged for your help
RE: Reason for commissioning sets being in the return leg
Commissioning set = control station?
I was told a long time ago that it was to prevent a coil air bound condition. I've seen it done both ways.
LTHW = low temp heating water
Commissioning set = Balancing valve
British terminology!
Return leg location is to keep the coil flooded as RossABQ mentioned.
With the return location, the coil remains under pressure from the pump at all times and thus insures turbulent flow thru the coil (3 to 5 FPS being ideal). If in supply, the coil gets only the water that is let in by the balancing valve (Oooops soooorry, the commissinoing set) and may result into laminar flow. Laminar flow is also equal to air build-up in the coil as RossABQ says (I suspect him to be a Brit as well with his "airbound" terminology)
Those are my two cents of explanation, there may be other reasons.
PS:
See, even with explanation, you brits confused our Baltimoran mauricestoker thinking about control valves instead of balancing valves.
Smile !!!
Still I don't see what difference it make w/r/t laminar or turbulent flow; if the valve is closed down, it's closed down regardless and flow thru the coil will be the same value. Only the airbound argument makes any sense to me, although the impact of a 3-way valve needs a little more thought.
Less flow will result into laminar flow, resulting into air build-up within the coil. Most coil MFTR's (and masterspec)recommend a water velocity of 3 to 5 FPS thru the coil.
If you happen to need 0.5 GPM on a coil that can handle 3 GPM, you would run into low velocity within the coil, heat transfer will likely suffer. Imagine pumping 1 GPM thru your car radiator, you wouldn't remove the heat. You need flow AND velocity thru the coil for proper heat transfer in my opinion.
Locating the Balancing valve in the return achieves full flow and proper velocity.
This is a good question for manufacturers, and I will definitely follow up on it with Trane and the likes.
You are a star!!!
Unless, we're talking about three-way control valves? I could see the location being more important in that situation.
I've seen balancing valves on supply and return (I specify on the return). I've seen control valves on the supply, and return to a coil or device.
Balancing valve location is usually not critical and only comes into play when the control valve is fully open. Velocity is the same on either side as Chris indicated.
Possible concern however with circuit setter on supply side: if system operates at low pressure and throttling occurs on the supply side of a coil, then the water takes the torturous path at elevated velocities through the coil, gases are more likely to come out of solution. The water will take the same path, at the same velocities, but it will do so at a lower pressure with the circuit setter on the supply. The throttling for these systems (esp. hot systems) is therefore better on the return side.
Control valves should normally be on the return side of hot or cold systems.
Reason for hot systems: 1) also throttling and keeping gases in solution, 2) reduce heat transfer to the actuator. Some actuator mfrs. indicate ~140-160°F temperature limits and require they be installed on returns. Heat can cause damage to electronics or reduce life of rubber parts, etc. in pneumatics.
Reason for cold systems: simply reduce the amount of insulation breaks on the colder supply piping. Also reduce sweat on the actuator (mainly for the electronic variety but can reduce life of pneumatics also).
Sorry to bring this note so late but these are questions that I used to wonder about quite a bit in commissioning systems and found answers I'm pretty comfortable with...
-CB
maybe this "commissioning set" is our autoflow device, which typically contains the manual air vent. air vent always goes on the coil outlet, or upper connection. this is to prevent air binding.
