Remove copy geometry from views in drawing
How I can remove the copy geometry from views in drawing? I have hide the copy geometry in layers and still when I place view it show the boundary of Copy geometry. I changed the the view to partial view and the others views that will come after it. Is there is an option in config.pro to control it.
RE: Remove copy geometry from views in drawing
so instead of putting the copy-geometry feature in a layer, but the elements of the copy geometry in a layer.
i know that works for surfaces, curves, and datum stuff.
good luck....
