Trouble with Appearances
Evening all,
I have copied a previous assembly of a tipper body, which I want to change the appearance of, so that it will suit a different customers colour scheme.
The previous assembly was a green olive drab colour, the new colour needs to be purple.
I have changed the colour of the individual parts to what I need, and I'm happy with that. But when I save the assembly it reverts back to the previous olive drab colour. In the appearance menu the assembly has the olive drab colour, so I opened the appearances menu and tried to remove it. But the 'Remove Appearances' button is greyed out.
I've tried saving, re-opening, restarting SW, restarting computer etc. but with no success.
Rather than clicking 'Remove Appearances', I can simply delete the assembly from the selections box. This will work temporarily, but when I come to save the assembly everything turns olive drab green again.
I've attached a couple of screenshots to try to illustrate the problem.
I would appreciate any help you chaps can give me.
Cheers!
System Specs
Dell Precision PWS690
Intel Xeon CPU 5120 @ 1.86ghz
3.00GB RAM
NVidia Quadro FX 4500
SolidWorks 2009 SP0.0 (Just realised this, I will update and see what happens)
Cheers!
System Specs
3.00GB RAM
RE: Trouble with Appearances
To check if this is the case go to the Feature Manager and hit the icon >> shown on the top right of the feature manager to show the "Display Pane" You will see [Asm Color / Part Color]
Iff you select the Assembly color in Appearance pop-up when selecting from display area you can remove the assembly override color
ht
Michael
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://www.robrodriguezblog.com
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
I upgraded to SP 2.0 in an attempt to solve the situation, which has only caused more problems, now PDM Vault Admin isn't installed on my computer, although the Installation Manager thinks that it is.
Sigh. I shall start a new thread. Thanks for all the help chaps.
