Shaft Delflection in API
I have exhausted many resources, and have not been able to come up with a maximum allowable shaft deflection in the API spec.
After looking through it, I came up with nothing. Is there no standard for this? Should I be looking more in the direction of the mechanical seal manufacturer instead? Thanks for the help.
RE: Shaft Delflection in API
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
The document is attached for reference.
Thanks again.
