time synchronous averaging
I am trying to write a program for time synchronous averaging of a signal in Matlab.
I am having a little trouble where to start as I have limited experience with this type of work.
The work is for a machine running a gearbox. The signal I am collecting is from the gearbox itself.
Does anyone have experience with this? Maybe just to start me off on the right foot.
Any input would be greatly appreciated.
Fe
RE: time synchronous averaging
y = (x(n-1)+x(n))/2
Fe
I have more then 500,000 data points to process.
Is there a more efficient algorithm?
Fe
If you have the data already "I would"...
y=zeros(1,length(sig_dat));
for i=1:length(sig_dat)-1
y(i)=(sig_dat(i)+sig_dat(i+1))/2
end
I am not working it in real time for now so the signal is collected beforehand then analyzed.
I understand that your proposed algorithm does average the signal over 2 data points which works well and pretty fast.
Also, I have another goal for this algorithm.
I am trying to synchronize the vibration signal of the gearbox with that of the speed of the shaft in such a way that any signals that have a higher frequency then that of the speed of the shaft are filtered out. This would enable to to analyze the signal further for faults in the machinery.
Is there a general method possibly?
Fe
f=250;
t=linspace(0,1,1024);
y=randn(1,1024)+sin(2*pi*f.*t);
plot(abs(fft(y)))
If so capture a long segment with 5-10 cycles.
use
cross=xcorr(sequence,sequence)
If the waveform is periodic there should be a peak on the cross correlation waveform indicating the shift, or cycle length.
If you get hear then break up into segments of this length and average them together.
ptengineer-
I am using FFT also. Although, I hope run this algorithm before the FFT.
2dye4-
Your periodic averaging description is pretty much what I am trying to achieve.
I ran the xcorr m-file and my results are attached. I am not sure what to do from here though. There is peak in the center.
How could I break it up as you say and average them together?
Fe
The peak at around delay 10000 tends to indicate a periodicity of 10000 samples in the fundamental period.
So averaging segments of 10000 may be productive.
If it were all in a matlab row vector use RESHAPE command to put the segments into rows and then average each column as a sample point.
ht
Thanks for the link sreid. I will consider outsourced equipment if my results are not what I expect.
all the best,
Fe
