Axis to axis move with compass
I am looking to move data using the compass, like the axis to axis in GSD. It is dumb data and I don't want a trail in my tree. Is there a way to do this using the compass?
RE: Axis to axis move with compass
No history and no typing.
#1. I am looking to have a way so to move it with out knowing/inputting the second angle orientation. Just like the GSD function.
#2. The SNAP you are referring to is in Product, I am looking to move curves in a catpart. Is there a SNAP in catpart?
Putting a jab a catia, UG has a repostition function that allows a copy or move, not that I want to return to UG.
Thanks for the suggestions.
This will move all data selected to the new location and keep the original name, colour, layer, geometric set...
Derek
I was looking for a compass solution, that seems to be quicker when using lots of lines or surfs. For the trans, rot, and axis to axis I turn on Create Datum but the original curves are still in the tree, you mentioned No Keep Mode, where is that? All I get is hide/show originals in axis to axis?
Ross.
You can use the distance and angle functions of the compass for simple moves. More complicated moves it will be difficult to lock axis tips from one to another.
Why are you moving the data inside of a CATPart and not moving a CATPart inside of a Product?
Derek
