Seismic Analysis Model
Does anyone know of a small (3 or 4 story) steel braced frame analysis model that was analyzed and designed using the 2006 IBC which has a published solution (something similar to the examples in the 2006 IBC Structural/Seismic Design Manual published by SEAOC?)
We're trying to compare several software packages and it would be helpful to run the same structure in each package and compare the results to published examples.
(the examples in the 2006 manual are not available for public consumption)
