Back calculating Vol flow rate
This seems like it should be a simple problem, but I feel like I'm going around in circles. How can I calculate the volumetric flow rate if all I know is the line size and the line pressure. I have a 1.5" welded, seamless steel pipe with 55 psi and I need to figure out the flow rate, assuming fully turbulent flow. What assumptions do I need to make? Can I use Bernoulli's? Any help is appreciated.
RE: Back calculating Vol flow rate
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
