Designing a dished disc in sheetmetal
I would like to design a dished disc in sheetmetal so I can "unfold" it and get an idea of what the preformed dimensions need to be. Is this possible? I can obviously draw the part as a solid but cannot convert it to sheetmetal.
Thanks for any help.
RE: Designing a dished disc in sheetmetal
Dan
www.eltronresearch.com
Dan's Blog
I think you are talking about metal spinning, rather than sheet metal.
You could assume that the disc will be bent from a flat piece of sheet metal, and break up the curve into discrete, flat sections. Is that what you want?
Diego
Thanks again.
I you just want an estimate on material usage get a die design handbook. There are formulas for hand calculating material usage.
Hold overs from before we had computers do the work for us.
Cheers,
Anna Wood
SW2008 SP5.0, Windows Vista SP1
IBM ThinkPad T61p, T7800, FX570M, 4 gigs of RAM
http://www.solidmuse.com
http://www.phxswug.com
Eric
ht
