Camber Length Minimum
I have always used a 30 foot minimum on beam length in order to specify any camber. I believe this requirement appeared in the Manual of Standard Practice in the 9th edition.
I cannot find a length minimum in the new 13th Edition specification or Code of Standard Practice. Does anyone know where I can find a value on minimum beam length due to fabrication limitations and what the specifics are concerning the equipment used to camber the beam?
RE: Camber Length Minimum
http://w
