To design a thin concrete wall
dear structural
i have to study a wall with 5 cm thickness with heigh concrete strength , it used to support flat plate slab edge wich is supported also by columns 0.12*0.12 m . for calculation without wall shows a deflection 1 cm in the middle of span 4 meters as shown in attached file ,in my case we put the wall between columns , now the wall resist the deflection how could the wall take that deflection and does any buckling happen in wall in this case , how should we design that wall
your idea is very important
RE: To design a thin concrete wall
do you know if etabs or sap2000 or any program can be usefull in this case , thanks
in fact the column is a steel kkr 120*120*10 full with concrete , and the wall concrete is c45/55 , , the researcher say it stand according to the labrotary testing , and i say its not according to the deflection of the slab and the buckling occer in the wall and i make some calculation in staad pro with buckling analysis , it shows the displacement in wall is 200 mm , i cant accept thet according to the feeling not calculation do u have any idea , or may be some one had a great look on this subject
your answer is very interesting
I agree with the others that it is too thin.
I assume kkr column is a steel hollow section; the concrete fill will have little practical effect.
Is this a research project or something that will actually get built?
i need your idea
It's not a homework, it's a real work for multi-storey building, it's a real economical solution, this research is submitted as an applicable solution.
Good Luck
Use WWF and perhaps some fibre mesh for the wall.
