k-? two equation turbulence model
I need to find two parameters in order to implement it in the CFD software we are currently using. The two parameters are; Eddy k Energy Field and Eddy length field.
I have been told that the length can be averaged between min and max values of the Nikuradse formula, and the energy by μ / (ρ * L), where L is initial length. I have not been able to find the Nikuradse formula, what is it?
Is it some other way of finding these two parameters?
RE: k-? two equation turbulence model
I see... The Haaland, Darcy-Weisbach, Colebrook etc. I have in my possetion. I need to find an equation that can estimate length of eddys and energy in eddys. This is to find friction factor f...?!
eddy diffusivity and the
velocity profile is discussed here,
http://www.journalarchive.jst.go.jp/jnlpdf.php?cdjournal=jnst1964&cdvol=5&noissue=7&startpage=354&lang=en&from=jnlabstract
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
I have looked in the previous link you referred to, and the turbulence model descussed in the paper are the mixing length turbulence model (...which are still widely used), not the k-ε two equation turbulence model. I am not a CFD expert, and so I have not figured out where to start searching. The eddy energy can be found from the eddy length and fluid property data, but I need to find an approximation of the initial eddy length based on input data.
Try a Google of "k-ε two equation turbulence model"
Pick the first free one,
http://www.texstan.com/m3.php
Also google k-w (Greek letters kappa and omega) turbulence model.
