Torque split math
Torque split math
Torque split math
I sometimes have problems with the term "torque split" when discussing a 4WD driveline. Consider this theoretical scenario on a very simple 4WD vehicle, discounting losses due to friction, etc. In fact, think of a the transfer case as a simple drop case where the driven gear is mated to both front and rear driveshaft yokes (no separate chain drive for the front axle). The engine is producing 200 lb-ft torque. First gear on the transmission is 3.0:1 and the transfer-case ratio is 2.5:1. That equates to 1,500 lb-ft torque. If you measured the torque at the each driveshaft, would the gauges read 750 lb-ft or 1,500? Remember, the driveshafts have a solid connection through the driven gear in the transfer case. If there is a 4.3:1 ratio in each axle (again let's use a solid connection like a spool instead of a differential), would each axle at the wheel hub get 6,450, 3,225 or 1,612.5 lb-ft of torque? Once I get this math down, I can tackle tougher scenarios involving traction control, viscious coupling, etc. where the torque split is manipulated. Thank you.
RE: Torque split math
Each wheel hub "could" see 6,450 ft-lbs but you don't really know what each one is getting unless you're measuring in real time.  Due to differences in tire rolling radius and gear/spline backlash you don't actually know what each wheel is seeing for torque even when driving in a straight line.  If three wheels were not in contact with the ground the one remaining wheel that was would get the full 6,450 ft-lbs (neglecting driveline friction).
Depends on the traction.  Slipping tires won't see much  torque.  The gears just force them to turn at constant speed ratios.
In an "ideal world", your example could apply 1,612.5 lb.ft. of torque simultaneously to each of the four axles.
Or 6450 lbft to any one tire. Or anything in between. Or, a negative torque on one wheel and then more to compenstae elsewhere.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
If you are considering locked differentials, the torque distribution will be analogous to a straight shaft with multiple brakes down it's length. With simple differentials the torque splits 50-50. large trucks with three driven axles have a differential that gives a 1-2 torque split. The "1" side drives one axle. The "2" side drives a 50-50 interaxle differential to power the other two axles. You end up with the torque split equally between three drive axles.
Bill
"Why not the best?"
Jimmy Carter
