API 5L-B for sour service
Refer to NACE MR0175-2003 Table D-2, material API 5L Grade A & B, Grade X-42 through X-65 have been accepted for sour service
But I don't find the limitation value of H2S partial pressure in both of API Spec 5L and NACE MR0175.
Can anyone explain this limitation?
RE: API 5L-B for sour service
I suggest you to use the new NACE / ISO 15156 part 2.
Regarding the H2S limit, there are no limits in terms of partial pressure of H2S for carbon steel.
there are limit for the hardness.
S
Corrosion Prevention & Corrosion Control
for gasoil services, above .01 Mol % of H2S and at temperatures above 396ºC you begin to have higher and higher corrosion rates for the carbon steels
lm
