AutoCAD .iges into Ansys
I imported an .iges from AutoCAD into Ansys but the scale of the geometry came in way off - 4 inch thick plate became a 0.25 inch thick plate.
The same thing happens when I bring in a .step file from AutoCAD.
Any thoughts?
Thanks.
RE: AutoCAD .iges into Ansys
You seem to know what the scale factor should be.  What I would advise is once imported to scale within Ansys.  In /PREP7 go:
Modeling -> Operate -> Scale -> ...
You should be able to find what you're looking to do under there.
