Hydorgen Mass Flow
Hydorgen Mass Flow
Dear all,
I need to convert 30.131 kg/m3 to a Nm3/hr, whereas:
The status: Hydrogen Gas
Working temp: 50 C
Working press: 4 bar abs.
Working density: 0.3001188349 kg/m`3
B/R
Kareem
Working temp: 50 C
B/R
Kareem
RE: Hydorgen Mass Flow
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
This is exactly the same conversion that purdster requested a few days ago in this same forum. Is this a homework problem for a school class?
Milton Beychok
(Visit me at www.air-dispersion.com)
It's not for a homework, actually am doing some calculation and i received this info from a vendor and need to find the equevilant in the unit of Nm3/hr.
actually as per our desihn flow is 550 Nm3/hr, but the vendor sent the orifice calc as per what i wrote, that is why am looking for this calc.
My best regards
Once you have understood what it is all about go to my web page (see my sig below) and download the free program Uconeer. It has a built in calculator to convert mass flow to volumetric flow, but you need to understand what you are doing in order to be able to use it.
Katmar Software
