Non compensated SMPS works fine
A circuit that doesn't work  is not nice, but a circuit that does work  when it shouldn't  is even worse!..........
I am designing mains LED lighting and am using UC3842 PWM controller since it  costs just 20 Cents. (Specific LED drivers are too expensive)
I have designed two similar current mode forward converters:-
1.    Uses a comparator (no loop compensation) to set the output current.
*****SCHEMATIC OF LED DRIVER  (NO LOOP COMPENSATION)
[IMG]http://i39.tinypic.com/906hp3.jpg[/IMG]
(switching frequency = 100KHz)
2.    Uses a compensated external Op-Amp  as an error amplifier to set the output current.
*****SCHEMATIC OF LED DRIVER  (WITH LOOP COMPENSATION)
(error amp zero = 63Hz, Error amp pole = 63KHz)
[IMG]http://i44.tinypic.com/2dam0ap.jpg[/IMG]
*****LT1241 DATASHEET
(LT1241 is very similar to the UC3842)
http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1003,C1142,C1137,P1332,D1328
The strange thing is, the  version with absolutely no loop compensation works just as well on the LT Spice simulator as the one with loop compensation.
Both versions give a very satisfactory 5mA of ripple current (ripple at switching frequency)
Here is the LED current from the non-compensated LED driver
*****LED  CURRENT (non-compensated version)
[IMG]http://i42.tinypic.com/2nh1dax.jpg[/IMG]
Here is the LED current from the compensated LED driver
*****LED  CURRENT (compensated version)
[IMG]http://i41.tinypic.com/2cifvnn.jpg[/IMG]
(The difference in current level is due to the different COMP pin resistor values)
LT Spice yahoo forum assure me that LT Spice does not lie.
The non-compensated  converter is  cheaper as it uses less parts.
However, I am worried about using it because from an academic viewpoint, it is not stable.
Do you think I would be allright using the non-compensated version.?
I know that  current mode forward converters have a double pole at half the switching frequency.
In the compensated version I have used a type II compensator to ensure that I roll the gain off well before this double pole, in order to give myself adequate gain and phase margin.
In the non-compensated version, the comparator  does not give the 180 degree minimum phase shift that the  op-amp compensated converter does.
-However, as the frequency gets extremely high, the comparator delay becomes significant and  it will indeed begin to show a phase.
-Indeed there will be a frequency at which the loop phase comes to minus 360 degrees,  and I am just presuming that  my loop gain has gone through zero before that happens. But has it ? I am doubtful
I have actually built a hardware version of the non-compensated converter  and amazingly it works like a dream and shows no instability.
.........Even though from an academic standpoint it is severely bad practice.
-It  cannot be induced to go unstable ...even switching the load repeatedly full_on and full_off doesn't make it oscillate.
I am afraid that I would have difficulty in deriving the modulator  transfer function for these converters as I am using non-standard configurations.
The power stage transfer function is straight forward, with a double pole at  half the switching frequency.
The error amp transfer function  is less straightforward as the upper divider resistor does not go to the output voltage , like in a "normal" voltage regulating SMPS.
The error amp transfer function  is Zfeedback/Zin .
-Usually, with a "normal" voltage regulating converter, Zin is simply the upper divider resistor.
........However, I am not sure what it would be with my converter.....i would presume, possibly wrongly, that Zin for the error amplifier would be the lower divider resistor, since the upper divider resistor is connected to an  AC ground.
-Also, I am unaware of the modulator transfer function due to the unusual configuration here.
Do you think I would be safe to use the cheaper, non- compensated converter ?
Or any thoughts at all appreciated.
Apologies for the length of this post
Thankyou for reading.
RE: Non compensated SMPS works fine
Your uncompensated circuit can easily work great on the bench in the lab (or in simulation).  What about variations in operating parameters, such as voltage, temperature, humidity, component tolerances, etc?  That's where you will probably run into instabilities.
At a first pass you should determine what two parameters your circuit will be most susceptible too.  Then you can run a 'four corners' test, by testing at the min and max of each parameter (X min/ Y min, X min/ Y max, X max/ Y min, X max/ Y max).  That will let you know how stable you are across drift in those two parameters.  Depending upon the circuit complexity and requirements, you can continue testing across the other parameters too.
Z
thankyou Zappedagain,
Actually , i am wondering now if my uncompensated circuit is maybe OK.
the HV9910B uses this uncompensated control and must be OK, i guess...
http://www.supertex.com/pdf/datasheets/HV9910B.pdf
also, the IRS2541 uses this type of control and must also be OK, agin guessing.....
http://www.irf.com/product-info/datasheets/data/irs2540pbf.pdf
and another one.....the FT870x
http://www.fremontmicro.com/pdf/FT870x.pdf
quoting from the FT870x datasheet (page 1)
"The FT870x is ideally suited for buck LED drivers.
Since the FT870x operates in open loop current mode
control, the controller achieves good output current
regulation without the need for loop compensation"
....so i am just wondering if there really is anything wrong with my uncompensated design?
"is anything wrong with my uncompensated design? "
The only way to really know is to build it and then test it across your environmental limits.  Before that there will always be some uncertainty.
You might be able to find a good applications engineer at Fairchild or TI (I'm not sure who's UC3842 you are using) who can provide some insight into when compensation is required.
Z
thanks zappedagain
i have built a version of this uncompensated smps led driver and it works fine.
it works so well that i think something must be wrong.
In a CCM Boost PFC stage, -they are also current controlled, but the current loop bandwidth has to be limited to 1/5th of the switching frequency.....so i cannot understand how i have gotten away with having no loop compensation at all.
(sorry to answer florsence's question, but i do work with him)
So what's the answer!?!  Do tell!
i'm afraid i don't know why they work, also, i don't know if they will suffer in a noisy environment due to the lack of loop compensation.
