Use of FEA in Sec VIII Div 1?
Hi all,
Is Finite Element Analysis an acceptable design solution per ASME Section VIII Div 1? Or is it permissbile only for use with Div 2 / 3 by a PE?
RE: Use of FEA in Sec VIII Div 1?
sp231, FEA is often used in Div. 1, as long as everbody, especially the AI, buys in.
Mike
It is acceptable only in the context of U-2(g).  It cannot over-rule a mandatory requirement of the Code.
What does U-2(g) refer to?
mcclain - what do you mean?  Read that paragraph in Section VIII, Division 1.  If you have any questions about, please come back here with that question.
