Surge tank characteristics
I asked a question in this thread
javascript:openindex(450,450,'http://www.tipmaster.com/includes/refinfo.cfm?w=450&h=450')
about variation in surge tank air volumes and it was suggested that they can vary by up to 20% due to temeprature.
Can anyone say how such a variation in air volume would affect the damping characteristic of the tank, I assume it makes it worse / better as you are going away from the design point, but I would like to understand how it affects the amplitude / frequency response of the system.
RE: Surge tank characteristics
If the air volume is changing due to temperature then the pressure is the same and, thus, your "spring rate" of the air doesn't change significantly.  The additional mass of fluid  now in the tank and its hydrostatic pressure may have some impact but I'm not an expert here.
we try not to double post here, so I answered the original thread.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
