thermoelectric cold plate, box materials
I'm working on a project where I'm planning to use a Thermoelectric cold plate with a 6" x 4" surface to cool a metal box with a 8" x 18" surface.
I'd like to get the box surface as cold as possible, and be able to maintain its temperature when sprayed with warmer water. It needs to be constructed with Anodized aluminum or Stainless.
Would the aluminum be better because it transfers heat better or would the stainless be better since it doesn't?
Any suggestions would be greatly appreciated.
Jason
Jason
RE: thermoelectric cold plate, box materials
TTFN
Then I start thinking that if the Stainless is less conductive it might maintain the lower temperature for longer, but then would I assume that less heat is transfered from the water.
