Hazen-Williams formula
Q=4.03 x 10^-5 x D^2.65 x H^0.54
I would like to use this formula to size a water pipe (D). I have Q from flow requirements. How do I determine H? The pump is rated 50 m head. Distance of flow circa 1000 m.
RE: Hazen-Williams formula
TTFN
You might wanna check out the on line calculator at:
ht
At 74th year working on IR-One PhD from UHK - - -
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
See htt
Katmar Software
Engineering & Risk Analysis Software
http://katmarsoftware.com
