Retrofit of 50ft Tall Sign
We have a client who is changing an existing sign. Problem is with the new wind loads the cantilevered (single pole) 24" pipe no longer works. Is there a way to strengthen it? Thinking about looking into solid grouting the core, just dont know if thats standard practice, do's vs don'ts.. Thanks
RE: Retrofit of 50ft Tall Sign
No longer works how? Is the pole too weak? Is it buried too shallow? Is it encased? Can it be replaced? Can you reduce the sign area? Can you weld stiffeners to the pole ? Can you provide sketch with dimensions, materials, and design wind speeds ? Can you add to the number if poles?
Mike McCann
MMC Engineering
back to the basics. when something doesn't work, review the load, review the material strength, review the support conditions.
Discuss problem with the Owner. The expense of strengthening the sign might convince him to reduce the size of the sign to bring it into compliance.
I already got all the info, the actual thickness of the pipe, etc...
How about longitudinally splitting a new HSS round section and installing it around the original column with groove welded seams. A plate at top and bottom can be used to connect the new sign at top as well as anchor into top of concrete footing at bottom. Might need gussets at base.
Connection is the hard bit.
Neilly Davies Consulting Engineers http://www.neillydavies.com.au
