Highschool Baseball Field Drainage
Part of my grading plan will be the design of a baseball and softball field for a new high school.
The infield scratch surface will grade away from the mound, both towards the dugouts and backstop. However, I am not sure how to collect the drainage from that point.
The dugouts and grandstand will both be on concrete at grade. If I don't drain the infield over the dugout and grandstand, somehow I need to pick up this drainage from the mound.
I was thinking perhaps an interceptor drain along the interface of infield and dugout/grandstand concrete. I imagine perf pipe with course rock backfill to the finished grade. From there, towards outfield and other site drainage
Anyone have an idea or experience with draining the inside perimeter of the infield.
It seems a width of rock at surface along this area might be problematic or unsightly.
The site is mosly clay, so I don't expect much infiltration. A prefab trech drain slots would be too wide, and would collect the infield scratch material.
RE: Highschool Baseball Field Drainage
With careful grading and topsoil you can get grades as flat as 0.50%. Also, you can use warning track areas to good advantage as collection areas. Steeper grades on warning tracks also serve as a reminder to fielders that they are approaching the fences.
Go look at a few good examples in your area and talk to the people who groom these fields.
I grew up on Chicago playing on 30' wide City streets and alleys with manhole covers for bases so don't go by me.
good luck.
Yours in Baseball,
Russ
http://
Baseball and Softball Fields: Design, Construction, Renovation, and Maintenance.
Puhalla, Jim; Krans, Jeff; Goatley, Mike
(John Wiley & Sons, Hoboken, NJ , 2003)
Offers guidelines, specifications, and tips for the creation, reconstruction, maintenance, and management of baseball and softball facilities. Stadium and field design, fences, dugouts, bullpens, irrigation and drainage, soil selection, turf management, field aesthetics, renovation, and skinned-area maintenance are covered, along with material w ith material addressing growing zones and seasons in North America. 240p.
ISBN-9780471447931
http:
Underdrains work fine, just make sure you use a double filtration method (perforated pipe wrapped in sock plus fairly large volume trench wrapped in filter fabric (geotextile). The trench cross section should be at least 4x the pipe diameter (no reference on that..just what I use when I design underdrains)
Since you have clayey soils in your area, be sure to select a filter fabric that will prevent passage of most of such materials.
(per EM 1110-2-1901, Appendix D)
