Link Parameter to iProperty
I'm using Inventor 11.
Is there a way to link model parameters to a Custom iProperty field?
I was hoping to link material overall dimensions to a material description field. For example:
Tube; 1/4"wall X 2 X 4 x 20" long
I would like all the numeric values link to the parameters.
RE: Link Parameter to iProperty
toolbutton in panel). Find the paramter of interest and check Export on the
far right. In this way, the parameter is being exported to Custom
iProperties. Then open your idw, and when you type in text change the "type" drop down to custom properties-model and your exported parameter should show up to the right in the property drop down then click the "x" with the down arrow next to the property and it will be inserted in your text.
I was hoping more for something along the lines of what this person did in the following link, but I didn't know if it was possible in some other way with R11.
http://di
http://www.leacar.com/
I would offer a caveat though. If you are planning to upgrade INV to R2009 + I wouldn't bother with LeaCar as it gets buggy from R2008 on. But for R11 it's great.
