Intumescent Paint
Intumescent Paint
Does anyone have any experience with intumescents relating to structural steel? Particularly the minimum steel thicknesses required to allow the use of this fireproofing. I have found ASTM E-119, UL X-625, X-628, and N-607. For Beams it appears the minimum steel thickness is 1/4", but columns a W8x24 is acceptable and has a web thickness of 0.245". I also know that there are certain humidity levels that will negate their function, and I am trying to use in a fitness center with basketball courts. Anyone know the max humidity level?
thanks in advance
thanks in advance
RE: Intumescent Paint
Let us know if you do that & post a link back here, so that anyone offering an answer here knows to go to the other thread instead. (You may also consider, once you've posted in the other forum, red-flagging this thread and having site management remove it so there aren't two parallel threads with responders unaware of each other.)
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
