ANSI/ASME vs. API Valve Ratings
I have a project that is asking me about the equivalence between the two but since I always specify valves based upon the ASME standards for pressure and temperature, flange bolting and the like (even if the valve itself is also governed by an API stanard), so I don't have much experience with the API rated valves.
I recall seeing a chart, possibly within a standard but I can not recall exactly where.  Can anyone help?
