Upper case instead of lower case
I never had an issue like this before SW2009 SP2.0.
I created an assembly by copying references and changing the names of the components. I've done this hundreds of times before. This time all the part numbers in the new assembly came in lower case, like g16s-11-202 instead of G16S-11-202. The problem is that they show up in lower case in the BOM of the drawing. Can anyone suggest a way to turn everything to uppercase?
RE: Upper case instead of lower case
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Eric
i don't know if this will solve your problem though. there could be something buggy goign on with the case.
rfus
