Too much field current bad for speed control in dc motors ?
In a shunt field dc motor, if the field current exceeds the rated, will it create speed control issues with a dc drive/encoder system ?
My client is running a 1.5 KW, 1350 RPM DC motor with a field current of 1.1 A as against the rated 0.74 A (I don't know yet why he is doing that). He is facing speed control issues like 20-30 rpm speed hunting even when the field current and armature voltage are constant. I think with nearly 50% more field current, the motor is going into saturation and hence speed control issues.
Any one agree ?
Any one agree ?
RE: Too much field current bad for speed control in dc motors ?
Field Volts : 220 V
Field Amps : 0.74 A
Armature Volts : 220 V
Armature Amps : 8.3 A
Speed : 1450 RPM
If it is broken, fix it. If it isn't broken, I'll soon fix that.
There is a possibility, though, that the higher excitation results in a higher torque constant (kt) and that you therefore get into instability if your phase or gain margin is narrow. But drives usually have quite broad stability margins. So, I do not think that this is a problem. Adjust speed controller gain somewhat to find out.
Hunting at low load is a common problem if the drive is a one quadrant type. Adding some load usually helps. Or limiting the controller's output so it doesn't do deep excursions in negative directions.
If the motor can take the heat, overexcitation should not be a problem.
BTW. The higher excitation voltage is probably because he has added smoothing capacitors to the field rectifier. Make him remove them to get normal excitation.
Gunnar Englund
www.gke.org
Does the EASA reference say that hunting can be caused by overexcitation? Or does it just mention "speed control issues"?
I have never seen any stability problems caused by high field current. And I think that I have seen and worked with more than 2000 different speed controlled DC drives over the years. It should have shown a few times if it was really a problem.
Gunnar Englund
www.gke.org
The EASA specialist says that hunting can be caused by over-excitation. I am also seeing this problem for the first time. I should know shortly whether my conclusion is right.
But I must say that I would listen more to myself than to an anonymous specialist - EASA or not.
The phenomenon has no physical explanation (except the slightly higher torque constant) and I have never found it in any report or text-book.
You bet USD 100? I have put a bill on my desk for you, marked Edison
Gunnar Englund
www.gke.org
OK. If I win, you should send that $ 100 to some charity.
That statement from you is worth a purple star!!
Yours
Bill
"Why not the best?"
Jimmy Carter
DayB
Got the feedback from the client today. Reducing the field current to its rated value, reduced the speed hunting to 5 to 6 RPM from the original 20-30 RPM. Three different encoders were used and the variation is still the 5-6 RPM.
Increasing the field current to 1.1 A (which is 50% more than the rated) increased the oscillations back to 20-30 RPM.
Is a 5-6 RPM speed hunt normal in the DC motor ? The problem here is that this motor is used a positional control and apparently constant speed is a must. Though the client is happy with the improvement, he is not yet delirious. I asked him to replace the Lovejoy coupling fixed on the motor which connects to the encoder just to rule out mechanical slackness.
The client was not confident of rocking the brush arm back as suggested by DayB since he lacks skilled staff.
Any other things to check ?
Gunnar Englund
www.gke.org
A 1 volt variation in supply voltage to either the field or the armature would account for that effect.
What is the motor driving?
Do you have an old analogue voltmeter that will respond fast enough to track the hunting? See if both the field voltage and the armature voltage are stable.
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
Asked him to send back the motor to my shop. Where I will check the speed again under constant field current and armature voltage. If the speed does not hunt, then his drive is a problem, which he has to fix.
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
Name Plate Details
Field Volts : 220 V Armature Volts : 220 V
Field Amps : 0.74 A Armature Amps : 8.3 A
No load run
Field Volts Field Amps Armature Volts Armature Amps RPM
137.5 - 137.9 0.60 185.8 - 186.1 0.3 - 0.4 1450 - 1452
152.7 - 153.1 0.65 196.7 - 196.9 0.3 - 0.4 1452 - 1455
166.9 - 167.2 0.70 205.3 - 205.7 0.3 - 0.4 1449 - 1451
178.4 - 178.9 0.75 211.4 - 211.7 0.3 - 0.4 1449 -1452
192.4 - 192.8 0.80 218.9 - 219.2 0.3 - 0.4 1450 -1453
207.9 - 208.4 0.85 226.4 - 226.9 0.4 1452 -1454
220.3 - 220.8 0.90 229.1 - 229.7 0.4 1449 -1452
237.2 - 237.8 0.95 235.4 - 235.9 0.4 - 0.5 1447 -1450
251.8 - 252.4 1.00 240.8 - 241.3 0.4 - 0.5 1452 -1454
Is that 2 to 3 RPM variation normal ? Could it be due to the variation in the armature voltage (which variation is beyond my control) ?
Everything is absolutely normal. I think that I win the bet. The problem is in the drive and the fact that they tried to run the motor with no load.
What happens then is that the speed controller "bumps" the motor to overspeed, swings back - usually to negative side - and the motor coasts down in speed. When speed gets below setpoint, the controller starts moving upwards and "bumps" the motor again. The cycle goes on until load is applied to the motor shaft so that the speed controller gets the reaction it expects.
There are two possible ways to correct behaviour at light loads; 1, make sure that the speed controller cannot swing in negative direction and 2, eliminate the integral part (at light loads).
This thread started with a question if too much excitation can make a DC motor unstable. The answer is NO. But it can make the loop gain a little higher so that the "bumping" is noticed more when excitation is high.
Gunnar Englund
www.gke.org
I will ask the client to check his controller again.
How do you want the $ 100 ?
Gunnar Englund
www.gke.org
Gunnar Englund
www.gke.org
1452 RPM x 99.84% = 1449.66RPM
1449.66RPM - 1450 RPM = -0.34RPM
-0.34RPM / 1450 = - 0.0235% or one part in over 4000.
The speed variations seem to be closely related to armature voltage changes.
Bill
"Why not the best?"
Jimmy Carter
Thanks Dick and Bill.
We tested the motor again at my shop with the client's dc tacho gen (0.06 V per revolution). For 1450 RPM at various field currents (from 0.75 to 1.0 A), the tacho output was from 87.1 to 87.3 V corresponding to 3.3 RPM max variation. My non-contact also showed the same variation of 3 to 4 RPM. There was 0.5 to 0.6 armature voltage variation which would account for this 3 to 4 RPM variation.
Now, it has been conclusively proved that there is nothing wrong with the motor and the drive at the client's site is the culprit.
Thanks once again for your tips.
