nagging display error in nx6
Can anyone give me advise me on the error " Error recovery completed for the following error: Internal error: memory access violation"
It happens over and over. I'm running nx6 64bit
RE: nagging display error in nx6
The error message is not very descriptive. In the log file (help->NX log) there should be a more useful explanation of what went wrong. Scroll down and then up until where things went belly up.
Thanks, I wound up call UG and updated Graphic card and Drivers. Problem Solved.
Thanks for helping.
Dear All
Can any body help me with the below area.
I cannot open the file due to below error.
"EXCEPTION: INTERNAL ERROR in line 6478 of D:\ugnx30\sandbox\src\part\no\ind\part_load"
Thanks in advance.
suhaimie,
What is that directory? Is it your installation directory or somewhere were you install the files. I suspect something is set to point to the wrong place but I can't tell what.
What version of NX are you running?
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
