isolation transformer
I need an isolation transformer. ratio 1:1, for PCB, low noise. Input voltage is 0-220VAC.
Any suggestion?
Thanks!
Best Regards
Hans Pettersson
Any suggestion?
Thanks!
Best Regards
Hans Pettersson
RE: isolation transformer
Keith Cress
Bill
"Why not the best?"
Jimmy Carter
You should "Red Flag" your message on this thread and use your other thread if it's the same problem. Two threads on the same question makes it tough to follow.
