Increasing distance for electric hybrids
Anyone think about adding induction coils in the suspension system to return some charge to the battery?
Using gravity to generate electric current may allow increased mileage per charge without creating drag. Thoughts?
RE: Increasing distance for electric hybrids
Downside; only increases range on bumpy roads.
Bigger downside; adds cost, weight, complexity, and failure modes.
Mike Halloran
Pembroke Pines, FL, USA
It has to be less than the difference between driving on a smooth road vs driving on a bumpy road all other conditions being the same.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers for professional engineers
Let's see 20mm at 2Hz is a velocity of 0.25 m/s, and you might get 1000 N/m/s damping, so that is a power of .25^2*1000, 60W, per shock, on a reasonably rough road.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Cheers
Greg Locock
