How to input load for a large element set
        I have a large elements set of around 700000 along with heat generation at that particular element and i need to input the loads( H gen) for these particular elements in ansys classic.As doing this manually would take a lot of time is there any method like reading the load file from some other format like excel or word or any other format?
RE: How to input load for a large element set
yes, from text file. This text file can be generated via Excel if you feel more comfortable.
Read the Manual under "how to apply loads".
