Help with press fitting two die cast parts
I need to find a good source on press fitting two metal die cast parts together.  Or any info you have on press fitting in general.
More specifically how much radial inferference causes how much pressure on the contact surfaces?
-M
RE: Help with press fitting two die cast parts
M
BS4500: ISO limits and fits.
"Mechanicas of Engineering Materials" by Benham & Crawford has a section on stresses set up by a shrink fit assembly.
Greg
