Holes on a curved surface
I have a cylinder where I want to counter bore a hole, 0.5" wide down .375 and then at that point inserts a 1/4-20 thread to the center of the cylinder which has a center hole .251 in diameter.
I set up an offset plane at the .375" mark and scrambled a solution but what's the best way of doing this?
RE: Holes on a curved surface
Dan
www.eltronresearch.com
Dan's Blog
