NX5 CHECK REQUIREMENTS
I am trying to setup check requirements using a spreadsheet.  For the compare column there is Range(<>), LessThan(<), GreaterThan(>) and Equal(=), but what is the "Phrase" for "less/greater than or equal to"?  What about "not equal to"?  These options are available when using the Ad Hoc method of adding requirements.  Is there more documentation for this available other than what is in the help system?
The NX help references this file: UGII_BASE_DIR\UGCHECKMATE\examples\requirement_spreadsheet_example.xls
NXdesigner
RE: NX5 CHECK REQUIREMENTS
I have not used checkmate, so take this advice with a grain of salt - try these out:
(<=) less than or equal to
(>=) greater than or equal to
(!=) not equal to
Please post back to let us know if they work or not.
