random vibration environment analysis
Hello everyone,
could anyone plase tell me what is the correct procedure to perform a structural analysis by FEA on an item subjucted to random vibration? I work in aerospace field and use NX.Nastran with Femap. I know the input PSD for this item and I would like to verify its strength. It includes some welded connections also: how are they usually modelled?
Thanks and regards
Thanks and regards
RE: random vibration environment analysis
Garland E. Borowski, PE
Engineering Manager
Star Aviation
The NX documentation should be able to give you all the information you need about setting up and running the models?
I don't use NX but Nastran with Femap as pre-post, with the licence for dynamic analysis. I am able to perform freq response and to apply PSD, but I would like to know how to consider the results, since I can have PSD of component stresses, and not Von Mises. Is there any standard procedure?
I know NASTRAN is capable of calculating the RMS VonMises Stress. I can also get X-Y plots of the PSD of VonMises stresses for an individual element.
