What is a Swing Check SubSea Valve?
A Customer is asking ma a swing check subsea valve.
The thecnical specification is not really clear, all the design is referred to API 6D. Only the coating spec. is special.
Do you have experience of standard subsea check valves?
There are some special features in the design or a swing check subsea valve is like a standard swing check valve with a special painting?
Do I need some protection for the body-bonnet bolting connection and for the body-bonnet gasket?
Thank you so much for your help!!!!
RE: What is a Swing Check SubSea Valve?
Ask the customer to clarify what _he_ thinks the specification means for you.
Mike Halloran
Pembroke Pines, FL, USA
If you buy and deliver one of these to him, he should be a very happy client.
http://www.c-a-m.com/cam/search/showdocw.cfm?DOCUMENT_ID=8791
"Pumping accounts for 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic  (Note: Make that 99.99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Thank you BigInch,
but I work for a valve manufacturer, to that Cameron is now my fist competitor. I don't want to buy the valve but I want to design a new product!!!!
By
Designing one better than Cameron's TW ~ now that ain't gonna be an easy task. Good luck.
