Autosave on Close
Autosave on Close
Greetings all,
We recently installed v2008 and there are a couple of users that are experiencing a problem when closing drawings. Normally after a change is made and you close the drawing or the AutoCAD session you'll get a dialog box asking if you want to save changes; Yes, No or Cancel. In this case no dialog box appears, the drawing is closed yet all the changes are saved. Convenient perhaps but not always the desired course of action one wants to take.
Anyone know what's going on here? I looked for a variable for this but could not find one.
RE: Autosave on Close
By any chance are any of your users using any third party software or add-ons for AutoCAD - maybe something they found on the net somewhere? It's possible the close command has been redefined via a custom VBA or LISP routine. The other thing to check might be the CMDDIA and FILEDIA variables, these control command dialogs and file dialogs respectively, and maybe these are just set to 0 and your user is just missing the prompt.
HTH
Todd
Sometimes changes made in drawings might not be expected to save.
