Scaling the ETABLEs
Scaling the ETABLEs
Hi everybody,
I would like to scale the results saved in the ETABLEs by using a factor in order to obtain the results in different units.
I tried to use the command SMULT as follows
SMULT, var, var, , factor
The problem is that the scaled values of var are saved for all the SET in the analysis overwriting all the values in the other SETs...
Idea?
Andrea
Idea?
Andrea
Dr. Andrea Mordini
Civil Engineer
Ph.D. in Structural Mechanics
http://www.andreamordini.com
RE: Scaling the ETABLEs
If you need to scale specific values within an element table, I would personally *VGET the ETAB values you need and store them in a defined (dimensioned) array. You can do this by using the *VGET command:
*VGET, ParR, Entity, ENTNUM, Item1, IT1NUM, Item2, IT2NUM, KLOOP
where "Item1" above can be used to get the ETAB values and store in array "ParR". From here you can scale individually.
Cheers.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Yes, in your way I can manage the output as I want, but I would like to visualize it on the structure using PLLS...
andrea
Dr. Andrea Mordini
Civil Engineer
