Horizontal Shear
Horizontal Shear
Hi all,
I'm designing a member that is supporting vertical load. The member is to consist of 2 steel beams, one placed directly on top of the other.
I want to design them to act compositely and therefore I want to use bolts to fix the top flange of the lower beam to the bottom flange of the upper beam.
I understand that it is the horizontal shear I need to calculate in order to calculate the shear on the bolts, but I don't know how to calculate this horizontal shear.
Can anyone shed some light on this subject for me?
RE: Horizontal Shear
DaveAtkins
If the clamping force of the bolts is sufficient to maintain full contact, the composite action will occur. I suspect, but haven't tried to prove it, that if you space fasteners such that no differential flange bending occurs, that will take care of any horizontal shear.
So is the following correct for bolts and welds?:
Horz shear flow (LRFD) = A*Fy
Horz shear flow (ASD 13th) = A*Fy
Horz shear flow (ASD 9th) = VQ/I
Can someone point me to where shear flow = A*Fy is specified in the 13th edition?
- Thanks
It's analogous to a composite steel beam.
