Tack Welds
Tack Welds
Tack Welds
I have always requested tack welding be completed within the parameters of an ASME IX qualified WPS. Product is not pressure-containing (not ASME B31). Is there a statement in ASME IX that requires tacks to be compliant with a qualified WPS?
RE: Tack Welds
No, not Section IX. This would be addressed in the construction code, like ASME Section I or VIII. All Section IX does is provide guidance for weld or braze procedure and welder/brazer qualification.
