Serrated pin
Serrated pin
I need some help. I am looking for a serrated pin of 0.8 milimeters (diameter) but I cannot find it. First at all, Does anyone know the ISO or another standard that it fulfill?
Thank you in advance.
RE: Serrated pin
RE: Serrated pin
RE: Serrated pin
http://www.goldnwax.com/images/earring.jpg
don't know if that's what the OP had in mind. also don't know if there's a name for it.
RE: Serrated pin
My local Home Depo has wire and plastic nails of about the size desired, with grooved (non spiraling) ridges.
At 74th year working on IR-One PhD from UHK - - -
RE: Serrated pin
From their list, you could look at:
DIN 7| DIN 6325| DIN 7979D | DIN 7979| DIN 7979D
ISO Specification
ISO 2338 | ISO 8734 | ISO 8735
The list probably has a lot of useless info. for you, but you don't specify axial, circumferential, spiral, or knurled "serrations" or grooves.
RE: Serrated pin
What I am looking for is as a slotted pin in which the border of the slot have something similar to a sawtooth. I think this could be for let more compresion in order to help the assemblie. I have a hole of 0.8 milimeter and I want use it to fix a gear to the axis of a motor to avoid rotation between their.
RE: Serrated pin
Producers of dentist equipment or watches?
RE: Serrated pin
http://www.spirol.com
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
