What's 316 SS compatibility with 304
Hi, does anyone know SS 316's compatibility with 316?
Please do drop more information or knowledge you have on this subject they will all be taken in and appreciated.
David O.
Mechanical Engineer
Graduate as of: 2007
Oil, Gas & Power
RE: What's 316 SS compatibility with 304
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
David O.
Mechanical Engineer
Oil, Gas & Power
Corrosion: compatible, 304 has lower resistance to Cl-
Other: they usually have terrible compatibility for threaded connections, especially with cut threads
Cory
I have not failed. I've just found 10,000 ways that won't work." — Thomas Edison
_____________________________________
David O.
Mechanical Engineer
Oil, Gas & Power
Hope this helps!
Dingus
Type 316—the second most common grade (after 304 for food and surgical stainless steel uses alloy addition of molybdenum prevents specific forms of corrosion. It is also known as marine grade stainless steel due to its increased resistance to chloride corrosion compared to type 304. 316 is often used for building nuclear reprocessing plants. 316L is an extra low carbon grade of 316, generally used in stainless steel watches and marine applications due to its high resistance to corrosion.
Hevs
Conveyor Manufacturers
www.conveyor-manufacturers.co.uk
