abaqus imperfection command don't function
I'm performing one analysis in ABAQUS 6.7.1,
I'm introducing a deformation using the command *IMPERFECTION:
*imperfection, file=RootJointExt, step=1, nset=ALL_NODES
1, 1.0
I receive this error when abaqus starts reading the
RootJointExt.fil:
***ERROR: AN ERROR OCCURED WHILE OPENING/READING THE FILE /data2/users/adangeli/run65_FL_2_1/RootJointExt.fil. MAKE SURE YOU SPECIFIED THE CORRECT FILENAME WITHOUT THE EXTENSION. FILENAMES ARE CASE SENSITIVE ON CASE SENSITIVE OPERATING SYSTEMS.
the problem is that one time it functions without problem, I tried to reproduce the simulation but it didn't work. what can I do?
1, 1.0
RootJointExt.fil:
RE: abaqus imperfection command don't function
