Masonry Horizontal Joint Reinforcing.
When using a #9 Dur-O-Wall horizontal joint reinforcing at 16" o.c.  What are the requirements for lapping this type of reinforcing at the corners?  Is the mason supposed to buy a prefabricated corner section to use in these locations or is lapping allowed?
I can't seem to find any requirement in ACI 530.1.
RE: Masonry Horizontal Joint Reinforcing.
With the ladder type, I generally lap it 'one rung' <G>.  I seem to recall Dur-o-wal has a discription of the splicing.
Dik
Lap ends of reinforcement 6". It is common to cut the interior wire and field bend the continuous reinforcement at corners.
