SYNCHRONOUS MOTOR 1100 HP, 4160V
I NEED INFORMATION, I HAVE A SYNCHRONOUS MOTOR 1100 HP, 4160V, START WITH SOFTSTART SOLCON HRVN, AND EXCITER GEFRAN TPD32.
NEED PARAMETER NECESSARY FOR TPD CONFIGURATION.
Gentlemen, yesterday energizes one of the starters in the mine, the soft start works fine until the engine has 257 rpm without any problem.
when the bypass contactor enters starts maneuvering excitement, has a period of approximately 10 sec, when this time is finish time relay TD off, R3 and R4 FAILURE TO INDICATE system stops (exciter and soft start).
The engine does not have temperature sensor and encoder.
MOTOR DATA
BRUSH TYPE
WESTINGHOUSE 1100 HP
VOLTAGE......4160 V
AMPERE.......157 A
%PF..........80%
PHASE........3
CYCLE........60
RPM..........257
EXC. VOLTS...125 VDC
EXC. AMP.....71.6
%LOAD........100%
HR...........24
°C RISE......50
MOTOR DATA
BRUSH TYPE
VOLTAGE......4160 V
AMPERE.......157 A
%PF..........80%
PHASE........3
CYCLE........60
RPM..........257
EXC. AMP.....71.6
%LOAD........100%
HR...........24
°C RISE......50
RE: SYNCHRONOUS MOTOR 1100 HP, 4160V
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
