Oxygen & Oil Explosion Hazard
Might be a trivial question, but I need a simple explanation for the reason of explosion hazard in holding oxygen and oils together.
Thank you!
Thank you!
Oxygen & Oil Explosion HazardOxygen & Oil Explosion Hazard(OP)
Thank you! Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Oxygen & Oil Explosion Hazard
If you have fuel (oil) and air (oxygen) always present, then if an ignition source comes along, you don't want to be there. Hence, by keeping air and fuel separate, two events have to happen at the same time, the fuel and air have to be there AND an ignition source has to be there all at the same time. The probability is simply reduced.
There are some other factors such as the right amount of fuel (between the upper and lower flammability limit) has to be present but this is the general principle.
The basis is the rate of oxidation. Think of a piece of wood - put 1/2 in the flower bed for 3 years to rot away and put half in a fire. Both are the result of oxidation, the later at a faster rate. Both generate the same amount of heat, one at a rate not discernable to the human touch and the other can cause a skin burn.
If you are refering to spontaneous combustion from an oily cotton rag, it is slower than an explosion, but faster than the rotting. The O2 does a little oxidizing which causes some heat. The little heat causes the air to move and draws in more O2. This cycle keeps on going until the heat is enought to erupt into flame. Did you ever put your hand into a pile of grass clippings about 2 days later? These have erupted into flame, especially hay piles on the farm. Oily rags have to have 100% air circulation (to dissipate the heat) or zero air circulation to prevent spontaneous combustion.
Now to the serious problem of oil and O2 explosions. Oxygen is looking for something to unite with and organic materials, such as oil, are its favorite target. When the O2 is under pressure, such as in cutting torch and hospital rooms, it will penetrate faster and deeper, which means it has more stuff to combine with and will build up heat faster than the stuff can absorb or dissipate. Thus, just the natural oil from the palm of your hand is enough on a compressed O2 fitting to cause it to explode after you have assembled it and turn on the supply valve.
The other side of this is when the O2 is not compressed, such as released into a hospital room, but the stuff of the room is super saturated with O2. Then it only takes a small spark to set it off, such as a cigarette or the spark of a nail in a heel of a shoe across a concrete floor.
Hope this helps with the practical and the chemistry understanding.
