CV valve definition
7
CV valve definition
CV valve definition
What is the exact definition for CV valve?
Is there a web site, which explain it?
Thanks, Aharon
RE: CV valve definition
3
Do you mean the definition for Cv with respect to a valve's capacity.
The Cv is the number of US gallons of water the valve will pass with a differential pressure of 1 psi.
The standard equation for a valve's capacity in liquid service is:
Q = Cv(dP/SG)^0.5
This assumes there is no flashing or cavitation of the fluid.
Q is the flowrate, gpm
Cv is the valve Cv
dP is the differential pressure, psi
SG is the specific gravity of the fluid
The process of determining the Cv value of a valve is quite impoortant... temp. must remain constant, valve should be tested between 5-15 psid, etc.  The Cv value is, to my belief, useless as a tool beyond a convenient number to compare valves.
Check into ISA standards, ISA-S75.02.
Take care
I think thats over the top
Other values such as loss coefficeint may provide a more accurate tool but for most engineering purposes Cv will do all right.
Best Regards
Morten
